another quickie about 1272 gainswitch
Jonkan
Sweden
I accidently broke the leg of the 110ohm resistor that goes to ground from the gainswitch in my 1272 clone.
Is it ok to use a 100 or 150 ohm instead, or does it need to be 110?
/J
I might,
So i just connect them in parallel?
Shall i take it then that it needs to be exactly 110ohm?
Cause it feels kinda silly ordering just one resistor..lol
/j
[quote author="Jonkan"]I might,
/j[/quote]
Should look at the circuit to see what the consequences would be, but just do what gets you going right now. So if you have 2*220 use these and if you have only those other values put these in and replace later on with the more exact value if required or just for peace of mind.
It's just setting gain, so a couple 220 in || or a 120R or 100R or 150R will work fine until you get the 110R. Just put what you got in there and crank that shit up !!! :green:
