[quote author="CJ"]Cool!
Obvoiosly a top secret project, right?[/quote]
No secret. What I have in mind is this:
I need a stereo limiter, and I need a small stereo monitor amp.
I love that LA2A-inspired limiter I've built some time ago, so I want this limiter to use the same method, opto electronic gain control, and a tube recovery amp. Then it occured to me that I might just build the pwer amp into the limiter, or add the photo resistors and control circuit to a power amp, depending on the way you look at it. Then I thought if I have extra 600R winding, I can use it as a regular line level limiter as well.
As I'm mainly going to use it on (virtual) mellotron and e-piano sounds, the next idea was that sometimes I'd like it with a little overdrive, and sometimes I'd like it clean. Sometimes I might even use it to monitor a virtual grand piano sound. Consequently, I just have to switch the opto limiting thing in and out, and I can choose between clean at a controlled, moderate volume, and overdriven. All in one box. Hopefully.
Which tube are you going to use for output?
That's the big question, and I'm still looking for recommendations. First I thought of some triode. (Parallelled 12BH7s ?). But for that transformer, a EL84 pentode would be the first choice. Gives even *some* Watts instead of just one watt. So maybe running it well below its max output level (like, +20dBm instead of +40dBm, I might get a pretty clean signal in "Line Level" 600 Ohm mode. (Is this fairly realistic?) And I'd have more power for driving speakers than the 1W amp I first intended to build.
I don't know. Maybe I'll go for a triode anyway. That transformer has UL taps, so not using the full primary winding, I might even get a primary impedance where various triodes might feel comfortable.
What do you recomment for this project: Should I go EL84, or should I use something different?
JH.
