JRE Productions
I have a line on some transformers that are rated at:
115V
ta60E talema 50/60Hz
acco to EN 60742 70024K
2.5VA + 2.5VA
18V + 18V
How does the 2.5Va relate to real amperage to drive circuits? I looked around to figure out VA verses AMPs. I would be using these to drive a API style circuit. Looking for about 15 to 16vdc. So I am trying to determine how much current they will supply.
PRR stated in another of my posts 18x 1.4 for total available voltage, and that the diodes would use up some of the power. So I am pretty sure these will supply enough voltage to run the opamps at 16vdc or so. But how many opamps can I run!!!!
Joe
115V
2.5VA + 2.5VA
18V + 18V
Joe
