[quote author="underthebigtree"]Try running in sel-sync mode. You are going
DAW track->R2R in record->another DAW track
In real time - in other words, you are only using the tape for its compression characteristics, monitoring directly, and going right back into the DAW. There is no drift.[/quote]
I doubt a '66 consumer machine had sel-sync but I might be wrong.
Tape delay is cool if it sounds okay, you know tape decks have this beauty-in-garbage-out thing goin' on. If you want a pre it's usually the first tube on the mic in and the last half of the playback line amp, add iron and stir. I would bet both mic/line and playback have an identical first gain stage, with maybe some extra eq parts on the playback, then 1/2 a 12AU7. If there's a full 12AU7 in front of the record head, the last half drives the head. So, from play heads I'm betting one 12AX7 and 1/2 a 12AU7 to unbalanced out; from mic in one 12AX& and one 12AU7; trace the line in and I bet it skips at least the first half of the 12AX7 if not the whole thing, gets about 8-9db of gain from 1/2 a 12AU7 to the record head driver.
'66 this thing would have been optimized for Scotch 111, not much slam there; more bets: it's got no eq adjust, no record calibrate, maybe playback hf and lf adjust, proll'y bias adjust, maybe bias calibrate and meter calibrate. To align it you'll need to buy a $130 alignment tape for 200nwb/0 db, you'll need a scope, a oscillator w/ attenuation for unbalanced in, a vtvm rms ac meter and a Simpson 260. If you can't find a free manual online you'll pay $45 for a xerox of one and it might not even have a scheemo in it, that or dig the Sam's out of the library. If you need belts you'll have to go on a belt safari, woo hoo.
Ugh, strip it for tubes, sockets, shockmounts, iron, knobs, pots, switches meters and throw the thing away.
Buy an Ampex ATR700 on eBone. Servicable, (it's a Tascam) slammable, (to a degree) says Ampex on it (elevates your street cred.)
Did I just age myself w/"street cred?"
