matthias
SSL : bal. / unbal. / 6db ? / 15k <-> 27k
« on: July 30, 2004, 03:09:15 PM »
Hi ,
I want to build a few ssl comps in the next weeks...
I've read in some other threads about that problem with bal and unbal.
so can anybody tell me in which cases I have to change the 15k resistors (that are leading into the vca in) to the 27k ones??
Is there a possibility to implement an "input gain" pot ??
If I would use a stereo pot at the place of the two 15k resitors, I'll get problems with l/r tracking, because of the tolerance of the pot
any suggestions ??
thank you
mat...
gyraf
« Reply #1 on: July 30, 2004, 03:22:07 PM »
Input gain control is not easily obtained. And you shouldn't really need one in this circuit.
For the unity gain mod, use the 27K resistors - this behaves best in any case.
Jakob E.
matthias
« Reply #2 on: July 30, 2004, 03:31:15 PM »
do I get unity gain at both cases (bal. and unbal.) when I put in the 27k resistors??
gyraf
« Reply #3 on: July 30, 2004, 03:35:06 PM »
Yes, for all normal cases 27K should do. I used those when I last did a test-clone, and it worked well.
The original 15K's had to do with some transformer balancing and debalancing stuff.. it's all very long time ago now...
Jakob E.
matthias
« Reply #4 on: July 30, 2004, 03:52:13 PM »
ok, thank you...
a lot of other equipment have a level switch for +4 and -10 dbu on the rear..
this made me curious, I thought it concerns to the 6db 15/27k thing..
ytrehalf
« Reply #5 on: April 13, 2006, 03:42:47 AM »
Does the 27K resistor value for the VCA input also apply for 202C?
Greg
« Reply #6 on: April 13, 2006, 07:53:42 AM »
Yup.
Greg Stein
New Orleans, LA
mathflan
« Reply #7 on: October 03, 2006, 10:33:12 AM »
I'd like to put a toggle switch to pass from 15k resistors to 27k resistors.
do you think that it's a good idea since I have to use long cable so as to connect the switch to the board? Perhaps it will give some noise?
Greg
« Reply #8 on: October 03, 2006, 11:40:53 AM »
It'll take you 10 minutes to wire it up, so just try it out and let us know  :thumb: !
Greg Stein
New Orleans, LA
dukasound
« Reply #9 on: October 03, 2006, 11:48:30 AM »
I did it with one switch on rear panel, if I used in insert unbalanced or in line - balanced with other stuff.
mathflan
« Reply #10 on: October 03, 2006, 12:21:00 PM »
you're right greg! let's go...
Last post May 29, 2009, 07:28:10 AM
by kambo
Last post July 05, 2009, 03:18:12 PM
by signalflow
Last post February 12, 2010, 04:05:16 PM
by warpie
Last post July 26, 2013, 06:20:11 AM
by tv
