JRE Productions
I just connect up an original 1272 module and have a question about the input. It appears that you can connect the transformer in series for 1200 ohm input, or parallel for 300 ohms. I assumed I need 300 ohms so I connected A-B and used it for Hi. And C-D and used it for low.
This works and sounds wonderful, but it seems I can distort the front end of the preamp. So, I am wondering if this is where my problem is. Or maybe its in the amplification stage itself.
I will be ordering one of Daves switches in the near future, but for now I only used a resister in the first stage of 56 ohms. Which is supposed to be about 30db. I left the second stage open for 18db (I think it was). Should these two stages be better matched? I think you can set each stage for very simular outputs. The over all output of the amp is not being overdriven, so I assume its in the first stage or the transformer.
Joe
Joe
