mnats
DIY JE-990 DOA
« on: March 18, 2006, 07:22:44 AM »
PDF and Gerbers here: http://mnats.net/JE-990.html
« Last Edit: May 12, 2010, 05:28:25 PM by mnats »
mnats
DIY JE-990 DOA
« Reply #1 on: March 18, 2006, 07:46:07 AM »
I don't have any plans to sell them, but my hope is that others will make boards from the Gerbers and distribute them locally. It doesn't seem sensible to ship a few 1.1"x1.1" boards halfway across the globe.
Etching them is only half the battle - without feedthroughs you have to solder certain components both top and bottom to complete the circuit. But I really wanted to include them in the PDF because some people might just want to try it out and won't have access to manufactured boards.
gyraf
DIY JE-990 DOA
« Reply #2 on: March 18, 2006, 08:55:09 AM »
Very nice job!
Is the latest layout version tested&verified?
Jakob E.
Viitalahde
DIY JE-990 DOA
« Reply #3 on: March 18, 2006, 08:57:19 AM »
Thanks, looks cool!  :thumb: I'm not sure I will ever build one though, I've understood it's a pretty tedious job. Will probably buy those from John Hardy..
mnats
DIY JE-990 DOA
« Reply #4 on: March 19, 2006, 01:08:48 AM »
Yes, the layout has been tested as correct. I hadn't run any audio signals through it when I first posted, as my oscilloscope is still in transit from the US (sea freight). But this afternoon I decided to pass some audio :evil:  Here it is driving an 8 ohm speaker to a pretty reasonable level:
It can apparently do this all day without heat sinks, just like Jensen says it can. Actually, he says it can drive a shorted output to full levels indefinitely. I'm not going to comment on the quality of the audio when I'm using a Rio mp3 player and a Radio Shack speaker, but I'll run some tests at school on Tuesday if I have the time...
There are 41 components on a 1.1"x1.1" board, or 108 transistors depending on how you want to count :wink: It's a picnic compared to repairing boards full of BGAs at work, but still probably not everyone's idea of a good time. Still, a manufactured pcb with feed-throughs and a solder mask would make it easy compared to a home-etch. The Gerbers are there on my site for anyone to make and distribute boards...
« Last Edit: December 25, 2009, 05:11:18 AM by mnats »
alk509
DIY JE-990 DOA
« Reply #5 on: March 19, 2006, 10:17:59 AM »
Mnats,
Are the output transistors thermally coupled to their biasing diodes? I remember reading in the Jensen 990 paper that this was critical, but can't really tell from the pictures...
Peace,
Al.
Lest laziness get the best of you!
mnats
DIY JE-990 DOA
« Reply #6 on: March 19, 2006, 03:28:23 PM »
Al,
Yes. That was one of the things that some earlier layouts didn't seem to address too well. You can see the evolution of my layout starting in the middle of  this thread. In the dale116dot7 layout, it looks like CR10 is touching Q9 but CR9 is coupled to CR3. I put pads at the edge of the board so the diodes can mount off-board and thermally couple to the output transistors.
The Fairchild transistors I used don't have the metal plate in the back that other brands seem to always have. But the collector leg seemed to give a good thermal link, and the diodes tuck right under the transistors that way:
« Last Edit: December 25, 2009, 05:12:12 AM by mnats »
hejsan
DIY JE-990 DOA
« Reply #7 on: March 19, 2006, 11:01:30 PM »
This is great news. Thanks for doing this.
I think I remember someone on the forum discussing that the inductors are impossible to get hold of. Will just any generic 20 uH inductor work?
Will 1/4 watt resistors fit there?
Hejsan
Just remember -- if the world didn't suck, we would all fall off.
Quote from: "Butterylicious"
mnats
DIY JE-990 DOA
« Reply #8 on: March 20, 2006, 02:15:48 AM »
Someone has the correct inductors or there wouldn't be JE-990s for sale! But the answer to your first question is in the Jensen paper: "Alternative (inductor) constructions would require an analysis of the effects upon open-loop response, phase margin, and transient response." I'm hoping that others with more experience and skill will build it and do some tests themselves. The first thing that comes to mind for me is that the DCR will most likely be higher with off-the-shelf inductors.
You could drive a truck through the space required to fit the correct inductors. They are almost 6mm in diameter and a little over 10mm high. But I'm not sure why you would want to put a resistor there - the 30R resistors are already parallel to the inductors in the circuit.
I was Googling around last night and found an interesting thread with some surprising comments by some people known to The Lab regarding the emitter inductors.
chrissugar
DIY JE-990 DOA
« Reply #9 on: March 20, 2006, 03:28:23 AM »
Hey Mako
Great work. Thank you for doing it.
chrissugar
Christian Mike Sugar
        CMS-LAB
radiance
DIY JE-990 DOA
« Reply #10 on: March 20, 2006, 08:25:36 AM »
Indeed great work :thumb:
How long did it took you to build one? (not including the design), say the time from a pile of parts and a pcb to a finished product?
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
dissonantstring
DIY JE-990 DOA
« Reply #11 on: March 20, 2006, 01:47:18 PM »
hey mnats,
i've been following this thread and i just have to say GREAT JOB!:thumb:
you always seem to take on things most of us dread or simply overlook when there's something great to be had from building it correctly.  i'm always amazed at the neat job you do, especially on something like a DOA.
BTW, i heard on the news that a cyclone went bowling through your way at 180mph wind speeds! :shock:   hope all is well with you, your girl and your home.  take care.
-grant
adrianh
DIY JE-990 DOA
« Reply #12 on: March 20, 2006, 02:58:51 PM »
mnats;
Finally someone posted a real Gerber file Yea!
This is how the big boys do it and now we here are doing it correctly.
These guys have a real nice Gerber viewer
that will allow you to print each layer. Just do not ask me how to use it.
You will need to give them your name and company name
so their marketing group know you are.
http://www.graphicode.com/pages/downloadprevue.cfm
Someone give Mnats a pat on the back!
The rf beads are sourced from http://www.fair-rite.com/
But the exact powder used they do not make anymore.
See the part# in the AES document.
Make a subsitution and get on with life.
hejsan
DIY JE-990 DOA
« Reply #13 on: March 20, 2006, 08:43:43 PM »
Quote from: "mnats"
I just meant to ask if it was possible to use normal 1/4 watt resistors in this board (as resistors, not inductors :wink: ) I mean would they fit or do they have to be 1/8 watt types?
Cheers'n beers :guinness: ,
Hejsan
CJ
DIY JE-990 DOA
« Reply #14 on: March 20, 2006, 09:04:39 PM »
jeez, do the boards have to be that small?
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
mnats
DIY JE-990 DOA
« Reply #15 on: March 21, 2006, 06:42:42 AM »
Hard to say exactly...I've made three so far...in between cups of tea, afternoon naps etc I would say about two or three hours. I spend a lot of time just looking at it trying to figure out which part to put in next so I don't paint myself into a corner, if you know what I mean.
Great work...GREAT JOB!...(etc.)
First of all, I don't think it would have happened without The Lab. There's a lot of knowledge in the back pages that I drew from and will continue to look probably for years to come. It's been about 10 years since Steve Hogan sent me a copy of the AES paper, I think. It would have still just been sitting there  collecting dust if it hadn't been for the pool of knowledge here.
Secondly, I have a very selfish reason for building these things. So don't think I did it just for altruistic reasons.
Yeah, I didn't get to test out the amp at school tonight because I was experimenting with inductors. I'll post some questions and observations later...
I just meant to ask if it was possible to use normal 1/4 watt resistors in this board (as resistors, not inductors) I mean would they fit or do they have to be 1/8 watt types?
That's what's in the board pictured at the top of the thread - normal 1/4W 1% resistors.
Dunno, but it seems to be the standard so-called 2520 footprint. Hey CJ, I'm probably going to ask you some really dumb questions about inductors so hope you'll be around this thread...
Xopek
DIY JE-990 DOA
« Reply #16 on: March 21, 2006, 08:48:14 AM »
Excellent work!  :shock:
I wish try to make one for mine Pultec EQ.
What replacements (on European?) transistors are possible?
2n4250a -bc... ?
2n2484 -?
mje - BD140/139?
TNX
I only observe... Because I speak only in Russian :)
mnats
DIY JE-990 DOA
« Reply #17 on: March 22, 2006, 05:50:19 AM »
Xopek - you might want to check this thread. But remember that pinouts on BCxxx devices are reversed to 2Nxxxx ones. Try out some replacements and let us know how they work.
What I was trying to say above is Thank You all who contribute to this forum - I couldn't have done it without you!
clintrubber
DIY JE-990 DOA
« Reply #18 on: March 22, 2006, 06:39:28 AM »
Quote from: "mnats"
FWIW, I saw the Jensen-patent had some specific coil-wiring arrangement through the bead. It's different from your pics but I don't think your experimenting is targeting this aspect of the inductors, right ? It'd surprise me if details like this are relevant, but who knows...
edit: ah, just read in the other thread you did need to do some experimenting here...  was it in the end caused by the winding arrangement or the core material ?
mnats
DIY JE-990 DOA
« Reply #19 on: March 22, 2006, 07:31:36 AM »
Funny, I used a completely different winding pattern based on the photos of the TSS version here and the description in the AES text. Thank you, I hadn't thought of looking at the patent :oops: So the TSS versions couldn't be using the pattern described in the patent text.
I'll try that pattern on the cores I have and measure them next week. But - and here's where my ignorance of inductors comes in - it seems to me that the total inductance is determined primarily by how many passes the wire makes through the core material. The text in the AES paper and patent seem to suggest that the reason for seperating the windings is to decrease the shunt capacitance of the inductor.
So I suspect that even though the core I found locally is the right size and shape, the material itself doesn't have the permeability of the core material suggested. It takes about eight passes through the core to equal 20uH with the bead I'm using. Of course this means that the wire passes through the same holes twice which I'm assuming will increase the capacitance and therefore will lower the resonant frequency...
How am I going to measure this with a generator that only goes to 1MHz or so?
« Last Edit: April 28, 2012, 06:02:25 AM by mnats »
Last post July 05, 2004, 03:42:43 PM
by daArry
Last post October 31, 2004, 09:46:04 AM
by Bear
Last post June 12, 2005, 03:16:35 PM
by daArry
Last post February 06, 2019, 01:50:27 PM
by Whoops
