dale116dot7
Comments on these?
The threshold and ratio pots will likely be replaced with a 6-position switch and fixed threshold and ratio settings on the SSM2018T compressor design, so there'll be input level, output level, attack, and release pots.
I haven't looked at the LA4 copy yet - haven't even calculated resistor values.
http://www.telusplanet.net/public/dulan/SomeCompressors.pdf
