PCB layout for PRR Vari-Mu
Kent did some work with PRR on this a while ago. I haven't built or tested this info personally but maybe others have...?
http://www.conditionedresponse.com/DIY/C5/index.html
:sam:
what is wrong with this?
http://www.conditionedresponse.com/DIY/C5/C5PCB.pdf
I etch it two days ago ,I just need a drill to finish it .
[quote author="12afael"]what is wrong with this?
I etch it two days ago ,I just need a drill to finish it .[/quote]
Yes, I have the same :grin:
as far as I know
Kent's site is still working and current
(we did think Kent's server was going to close)
it should agree with the stuff at the Factory
http://www.diyfactory.com/projects/diy12au7comp/diy12au7comp.htm
PCB
http://www.diyfactory.com/projects/diy12au7comp/C5PCB.pdf
PRR's original page
http://music-club.rutgers.edu/headfonz/comp5/Comp5.html
note how long ago it all was
PRR, May 2003
time does fly
:cool:
It works. that layout is good. I built two, one for use, the other for playing around with various ideas like class A output and such.. i'm real close to having that done too.
Sorry to be a grouch, but... geez, must there be a PCB for every project? Ya could wire that up on a piece of perfboard in less time than it takes to talk about making a PCB. I could understand needing a PCB if you wanted to make a hundred of 'em, but...
for the input trafos I used the radio shack trafos that PRR suggested. they work much better than you would think.. to the point of not noticing them at all. for the class A output I am using sowter 8751(?) and ba283s. I might try some edcor replacements too.
The only thing that I'm having a hard time rapping my head around is how to hook up the attack and realease. I'm going to build a stereo unit, and what I'm reading on the websites and layout isn't sinking in. Also....hooking up the meter since there are two meter sections on the PCB. Do I just connect to one of them?
For the attack and release....it says on the layout something like from ATT to ATT/REL from REL on channel 1 then from REL TO ATT/REL from ATT on channel 2. This is going over my head.
Any help?
[quote author="NewYorkDave"]Sorry to be a grouch, but... geez, must there be a PCB for every project? Ya could wire that up on a piece of perfboard in less time than it takes to talk about making a PCB. I could understand needing a PCB if you wanted to make a hundred of 'em, but...[/quote]
I remembered thinking the same thing the fist time I looked at the schematic, pretty light on the parts...
How good/accurate can the tracking of a stereo varimu be. Mastering buddy of mine likes the look of this but he don't want to master in MONO! :wink:
