Question about WIMAs
Purusha
Somewhere on the Planet
I will put some Wimas into my G-SSL soon but don't know much about them.
I found some not so cheap Wimas in one local store. This would be - POLY 0,1uF 100V 5% R5
Wima's official name for this caps is MKM2 http://www.wima.com/navig/mkm2.htm
I wonder if those 5% Wima caps sound much better than 10% Wimas which I found here http://futurlec.com/CapPolyester.shtml They are much cheaper but they are all 10%. Would 5% be better?
I am from Europe so any suggestion where to order them will be nice. Thanks.
Thanks. I am about to change those 25 100nF caps marked as .1 on the main G-SSL board. So 10% would be just fine for this purpose?
I just noticed that I can chose between :
-Metallised polyester capacitor, LS 5 mm
-Polyester/metal foil capacitor, LS 5 mm
...so which one are better?
Got to be careful with the Wimas on the GSSL board - get 63volts and not 100volts
The 100volts make life a bit of a problem with real estate (they are a bit too thick) - pin spacing is fine
Quick guide of thumb for pin spacing
02 = 2.5mm
2 = 5 mm
04 = all over the place
4 = all over the place (up to 27.5mm)
http://www.groupdiy.com/index.php?topic=7239&highlight=wima
My GSSL's have WIMA MKP-2 (red) for the 0.1uF caps and FKP-2 (green) for the 100pF caps, although they are really a pain in the a** to stuff, along with the ELNA caps, which are also huge in size. One of the green ones had to go under the board... but it sounds great!
cheers, Marten
[quote author="martthie_08"]My GSSL's have WIMA MKP-2 (red) for the 0.1uF caps and FKP-2 (green) for the 100pF caps, although they are really a pain in the a** to stuff, along with the ELNA caps, which are also huge in size. One of the green ones had to go under the board... but it sounds great!
cheers, Marten[/quote]
Thanks Marten. Where did you order them? Can't find the MKP-2.
Would these be OK? There is no info on the voltage...
MKS2 http://www.musikding.de/product_info.php?cPath=56_59_90&products_id=236
FKP2 http://www.musikding.de/product_info.php?cPath=56_59_101&products_id=746
[quote author="Purusha"][quote author="martthie_08"]My GSSL's have WIMA MKP-2 (red) for the 0.1uF caps and FKP-2 (green) for the 100pF caps, although they are really a pain in the a** to stuff, along with the ELNA caps, which are also huge in size. One of the green ones had to go under the board... but it sounds great!
FKP2 http://www.musikding.de/product_info.php?cPath=56_59_101&products_id=746[/quote]
After reading that post I used the FKP2s as the 100pfs
And used MKS2s (I think the MKP is a misprint)
I soldered them last night with Elna Cerafines - serious stuffing problem
Nearly all the left hand side of the board the MKS and FKPs where soldered onto the bottom (those cerafines are fat m**f***ers)
I used C0Gs for the 22pf and 33pfs
If you solder them onto the bottom the voltage doesn;t make any difference
I got mine from Musikding as well - I think I got a bunch of different voltages (63V and 100V) when I ordered
well, I have a "conrad" electronics store around the corner, so I just got them there. But check online for www.conrad.de or the other usual suspects, like www.rs-components.de, they should stock them.
MKS2 is metallized polyester, MKP2 metallized polypropylene - I really don't know if they will sound different.
http://www.wima.com/mks2.htm
http://www.wima.com/mkp2.htm
http://www.wima.com/fkp2.htm
Be warned, the FKP2 are pretty big suckers for the SSL pcb and I am really not sure if this is the right kind of cap for its application. You might try high quality ceramics first, more expensive is not always better.
Should I use the ELNA cerafines 22pf and 33pfs which you mentioned or will any other brand be ok too regarding the sound?
I have problem finding the 100uF and 22uF Nichicon caps in Europe. Anyone?
The 22pF and 33pF uk03878 is using are COG ceramics, not ELNA electrolytics.
me too, that's why I went with ELNA. cheers, Marten
oh - and whether Elna cerafines are better then anything else - that is not a educated decision on my part
I do not have the education to make that decision
I bought a stack of Elnas Cerafines at a big discount from Audio Cube in the Ntehrlands and am stuffing them everywhere
Ever seen a BA283AM stuffed with Wimas and Cerafines - you will soon!!!!
I got to have those Nichicons, there must be a way to get them :evil: :green:
What about the SMD versions? Any good?
:idea: Hey Greg, would you be so nice and buy for me some Nichicons in USA and send them to me? I can't find those values here in Europe. I can send you the money like for the HP filter boards.
Before I start ordering WIMAs. Are there any other capacitors needed beside the 0.1uF and 100pF for G-SSL which will give better sound results? OK, I know the 22u and 100u Nichicons for the input and output section are also wanted.
I guess my question has been answered too many times so nobody wants to answer it again. Fair enough ...
Actually, I don't really understand your question, do you want to know which other caps you need for the gssl in addition to the 100pf, 0.1uF and the 100uF / 22uF? Maybe take a look at the gssl BOM list available somewhere on this forum, maybe that will make things clearer. cheers, Marten
I was asking for some suggestions regarding which are the most important capacitors inside the G-SSL. I have all my G-SSLs already packed with capacitors I got in local shops (Jamicon and no name brands) but would like to change those which are the most important with WIMAs and Nichicons. I hope it's more clear now.
OK. Which ones are the most important to change?
[quote author="Purusha"]I wonder if those 5% Wima caps sound much better than 10% Wimas.... [/quote]
Seriously, why on earth would 5% sound better than a 10% tolerance capacitor? :roll: :roll: :roll:
