matthias
hi,
I'm just thinking of another mod for the ssl comp.
the api2500 has a switch where you can select "old or new style"
new= the sidechain gets its signal from the inputs (as it is in the ssl comp)
old= the sidechain gets its signal from the output of the vca (feedback compression like the 1176)
this should be also easy to implement in the ssl comp.
can somebody tell me if this would work:
cheers,
mat
cheers,
mat
