khstudio
PLEASE help with EVENTIDE H910
#1 - I could use a schematic.
I think 2 of the DBX plug-in expansion cards aren't working.
There's 3 all together:
slot - 1 seems to work the input + compression
slot-2, expansion #1 (output/efx/delay)
slot-3, expansion #2 (output/efx/delay)
Someone mentioned moving the cards around to help troubleshoot... so I did & noticed that only ONE of them made the INPUT LIMIT Light work :?
But no output. YES, the 3 cards are exactly the same. Just my luck it's probably 2 bad cards & I THINK you need at least 2 to get signal thru?
It uses these IC's
LF353n (x2)
RC4558p
DBX8032
& transistors
BC453c (x2)
:?: Are any of these components KNOWN to be weak :?:
Kevin
It uses these IC's
LF353n (x2)
RC4558p
DBX8032
& transistors
BC453c (x2)
Kevin
