Hello,
I recently began to use my GSSL compressor I've built. All controls work fine and the compression sounds right. But left and right channel doesn't compress quite the same amount. Yesturday I ran a mix thru it and recorded it into Logic Audio. See a picture of the mix in Logic. I've used gentle settings on the SSL, and the left channel doesn't compress as much as right channel. One can hear it also.
My SSL is using 202XT vca's.
Is this a calibration problem? My friend has an oscilloscope, he can probably do measurements on it if we know what to measure.
