Does anybody have a schematic for Amek Big Channel strip?
dramadisease
portland - or
I might be working on one in a few weeks, wonderin` what i'd be getting into. Anybody remember what the SSM chip in the micpre was that is discontinued? That would be quite helpful to know!
thanks!
may want to check with these guys..
http://www.audiomaintenance.com/home.htm
you can look up stuff using a module search field. Just click on the Amek link on the home page.
Gil
thanks for the awesome link, though I was hoping for a little more depth into the circuitry behind the 'BIG'!
or maybe why the hell they called it the "big" ??
thanks!
SSM Mic amp chip that was discontinued?
If memory serves, that'd be the SSM2017
pin for pin with the INA217.... or, if you want lower noise, INA163 - although the gain resistor may be different.
http://www.analogzone.com/avp_0923.htm
cheers
R
SSM2016 - in the mic pre.
No direct plug in replacement available. You must use an adapter board with a SSM2019 or THAT1512 since the SSM2016 is no longer made.
peace,
Joe Gianini
GRS Systems
http://www.grssystems.com
