wolfgang
Re: JLM Baby Animal
« Reply #1000 on: November 06, 2010, 06:08:51 AM »
What I dont know is:
- where do the red/green/blue/yello cables under OEP go....Seems that they will be going to power supply....will I have any switch or just the one from power supply
The spots with colour markings are for the JLM Input TX which has leads instead of PC-Pins.
So just put the OEP in where it fits and solder it ! Forget the colour holes - you dont need it!
- The CL and 0.1 uF...? do i connect them in the inner holes or the outer? (all photos I've seen are the older PCB's with just one pair of holes)
solder them where the cap fits better! they are connectet together!
- Where does the LED go to? (Is it to show the phantom power is on or not? where does it get attached?)
You have to solder the LED directly to the 48V Switch! I dont know the right legs out of memory but i am sure you will find he information oon the JLM-site!
- I am left with a circular plasitc small bit (size of led light)... where does it go?
This is for the JLM Input TX! you have to screw it and this small washer is to keep distance between the TX and PCB. So to NOT have any short!
I hope this helps!
enjoy the preamps!! they are great!!
regards,
Wolfgang
korni
Re: JLM Baby Animal
« Reply #1001 on: November 06, 2010, 08:33:43 AM »
It certainly does help!
Thank you very much wolfgang :)
So the power supply where does it connect to? (is it one from ''0v'' and one from ''+V'' to the PS? )
I Am What I Am
And Most Certainly
I Don't Need You To Accept Me
wolfgang
Re: JLM Baby Animal
« Reply #1002 on: November 06, 2010, 07:58:47 PM »
yes thats right!! check polarity of the psu before you switch it on!!!
regards,
Wolfgang
korni
Re: JLM Baby Animal
« Reply #1003 on: November 06, 2010, 08:00:12 PM »
regards,
Wolfgang
Thank you wolfgang :D
Edit: I guess I can avoid the polarity check if using a DC socket....
« Last Edit: November 06, 2010, 08:07:49 PM by korni »
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1004 on: November 07, 2010, 07:47:37 AM »
I always check the opamp-pin polarity before inserting the opamp! i dont want to burn a 40-50 Euro Opamp by accident!  :)
wolfgang
korni
Re: JLM Baby Animal
« Reply #1005 on: November 07, 2010, 08:26:51 AM »
Thanks for the advice.
Though I dont even know how to go about it...
I will search it :)
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1006 on: November 07, 2010, 09:02:25 AM »
Maybe i used the wrong words, my english isnt very well!!
I meant: Measure V at the PCB  Pins where you will put in the opamp.
Measure the V+ Pin and the V- pin! to be sure there are the correct voltages!
wolfgang
korni
Re: JLM Baby Animal
« Reply #1007 on: November 07, 2010, 09:18:57 AM »
Dont worry. I understood what you meant.
Me too have the same problem + I am a newbie :P
I Am What I Am
And Most Certainly
korni
Re: JLM Baby Animal
« Reply #1008 on: November 10, 2010, 01:26:31 PM »
Back with my power supply on.
Wolfgang you where so wright.
I get a bunch of voltages as 0 instead of +24V (as shown on the schematic)
I uploaded this image...
where there is a circle I get a 0 reading....
Also there is one reading I dont know wether I should be getting anything or not and circled it....
Any help please? Seems as a mistake carried on but cant find it......
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1009 on: November 10, 2010, 03:14:44 PM »
Hello!
for the markings at the opamp:
take a closer ook to the image of jlm : above the pcb in yellow:""""NOTE.  pins -In and Out  will be 0V with no Opamp fitted.
So this is OK! you can measure again with opamp fitted and you should get the 24V!
For the other spots: it i difficult to see on the picture but one of the caps is connected to the output pin of the single opamp. So it is ok!
one cap is connected to the second output pin of the dual-type opamp( if you use a OPA2604 instead of the JLM Opamp for Example) So this is ok!
the third is connected to the -In pin and RG. which then goes through the Gain-pot to Ground.
so this ok too!!
I think you can insert the opamp and have a test run! Measure again with opamp fitted!
(but do it on your own risk :) )
Regards,
Wolfgang
korni
Re: JLM Baby Animal
« Reply #1010 on: November 10, 2010, 03:19:58 PM »
 ???      :P
I feel stupid for the OPAMP in and out  ;D .....
Thanks for the help...
I will wait for Joe to give me an answer or something if he finds the time...
If not I will try with the OPAMP in tomorrow...
I am really thrilled I am finishing my first DIY project  ;D
Thanks once again wokfgang
much appreciated :)
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1011 on: November 10, 2010, 04:33:03 PM »
You are welcome!!
I think your build is on the safe side with your Voltage readings!
JLM BA was my first project to btw!!!
I have 12 channels now!
You will like it!
wolfgang
korni
Re: JLM Baby Animal
« Reply #1012 on: November 10, 2010, 06:20:45 PM »
hah...
Someone can easily get addicted to it!
Joe said to me that the reading's of voltages are good to continue
and check that there is no dead short (dead short = 0 ohms as he explained)
in between -in and 0v
and out and 0v
to the opamp....
It should be a few hundreds...
BUT
I cant get my hands round that and always get different value.... ???
It is so frustrating when you dont get a fixed value.....
I want black and white....not colours :P
If it wasnt for you wolfgang and Joe...
I dont know how I would have coped with it....
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1013 on: November 10, 2010, 06:30:22 PM »
and out and 0v
to the opamp....
BUT
But you never read 0V??
Is the Ohms value instantly inreasing or decreasing? or is it up and down ? ( if you measure and dont disconnect for a new measuring)
wolfgang
korni
Re: JLM Baby Animal
« Reply #1014 on: November 10, 2010, 06:59:51 PM »
It just behaves crazy...
Going up and down
at a very small rate...
Anyway,
Apparently as Joe said it must be due to the capacitors and the (low) quality of my meter...
As long as it doesn't give me back a reading of 0Ω then it's ok...
Tomorrow then I will be attaching my final xlr plug
and be testing the Baby Animal.
Cant wait :D
I Am What I Am
And Most Certainly
wolfgang
Re: JLM Baby Animal
« Reply #1015 on: November 10, 2010, 07:16:00 PM »
I thought also of Capacitors behavior!!
Anyway,  let us here of your tests!!!!
wolfgang
korni
Re: JLM Baby Animal
« Reply #1016 on: November 11, 2010, 12:14:48 PM »
Ok ,
voltages are ok.
Only that when gain goes more than 70% I get a noise..
(I don't know if this is normal or it is going to disappear if I attach the 0v to the case...but I am not that worried)
Final things is the LED
and a case (plus grounding the pre-amp to it)
It has very nice sound...
Even though I don't have experience with pre-amps I am amazed :D
Just one question...
if I want to put a power switch to the board
what specks should it have?
As soon as I make a case I will be posting the final pre-amp... :)
I Am What I Am
And Most Certainly
Re: JLM Baby Animal
« Reply #1017 on: December 27, 2010, 05:32:43 PM »
Here's my 8 channel BA modified to put a brazilian DIYed 2520 melville (thanks Fabio).. Cinemag input and output xformers... awesome!!! The preamps sound fat and punchy!!Api should put those cinemag output xformers instead of the profile's, the difference is remarkable...
It's like I wanted it, there's nothing like this on the market.. 1 RU, 8 channel hi quality preamps with input and output transformers..A big THANKS to my friend to Neeno of course, he did a terrific job! and to Cinemag for the great xformers! and of course to JLM for the pcb boards..
I called it the 812a... check it out.. (and for those who might have a doubt there's more than 92db crosstalk separation between the channels..and in the front pic it wasn't finished yet, but it's done now)   ;D
Ciao
Cheu
« Last Edit: December 28, 2010, 06:02:48 AM by cheu78 »
Re: JLM Baby Animal
« Reply #1018 on: December 27, 2010, 05:33:44 PM »
and here the guts!!!  ;D ;D ;D
Ciao
Cheu
« Last Edit: December 27, 2010, 05:46:49 PM by cheu78 »
regularjohn
Re: JLM Baby Animal
« Reply #1019 on: February 01, 2011, 02:01:40 PM »
Does anyone know where to find documentation to build the BAD with a cinemag 75101 input trafo?
It seems there's not a whole lot of info - or really any at all - on the BAD with that trafo.
SATANOSCILLATEMYMETALLICSONATAS
Last post August 01, 2006, 10:38:38 PM
by mattmoogus
Last post December 11, 2006, 05:01:06 AM
by zul_nalury
Last post December 14, 2018, 05:42:13 PM
by dysenterygary
Last post February 01, 2019, 03:27:33 AM
by analogica
