Hey guys,
I did some search here and also looked at the meta and found Keith's power supply, since my knowledge is very limited, I got stuck after switching the regulator to a 24V reg and eliminating the -18V section from his schem.
here it is:
www.braudio.com/forumfiles/PSU_24and48.gif
I was also thinking about using one of these..
http://www.advancedcomponents.com/store/transformers/pdf/SPK030_0606_1.PDF
Just not quite sure if I could go with the dual 18V or just go with the dual 24V
What else would I have to change on this???
I'm just building this to run a single Fetboy, just so you know..
thanks
Gil
here it is:
thanks
Gil
