Hello, i made several G9 through the years, my first was in 2006 i think
i replaced the tubes a couple of time since then and they have been used quite a lot
since some days, i have a weird hum at 50Hz coming up after some minutes of use ( 15-20 minutes )
It is the same on both channels
When i put all volumes and gains down, the main hum drops significantly but still exists, if i reverse the phase on one of the 2 channels, the hum disappears, when gain and volumes are up, with phase reverse i dont get rid of it, so the hum is well amplified and distorted by the tubes
i compared voltages with my other builds and everything seem fine more or less 5% so i guess it is very fine
i tried to replace the tubes and no difference
Any advice where to check ?
thanks for the help
