soundguy
1176 rev E vs rev F question
« on: May 05, 2006, 04:27:28 PM »
I have to work on an 1176 today and was comparing some points on the rev E vs. rev F and have a question-
If you look at the caps at the send and return to the output gain pot, the rev E shows a 1uf/40v electrolytic from the preamp to the pot and a .15uf  cap from the pot to the line amp.  The rev E calls for a 250K pot.
The rev F pre amp feeds the pot with a 47uf/40v electrolytic and returns to the line amp through a 1 uf cap.  The rev F f calls for a 100K pot.
Obviously the line amps are totally different animals in these, but the preamsp are for the most part the same.  I plan to experiment right now to see if there is any difference I can hear between these two set ups around the gain pot as its audio coupling.  I was wondering if there is any theory to accompany this or if anyone had any thoughts in general as the values are a bit different.
thanks
dave
chips are good with dip...
Last post August 04, 2007, 09:38:01 AM
by kato
Last post August 05, 2008, 05:34:25 PM
by EmRR
Last post September 15, 2008, 12:49:31 PM
by Ptownkid
Last post January 25, 2019, 09:15:42 PM
by MiamiBoy
