llamaj1
Im getting ready to start using this machine and I realize that ill be going through the line inputs on it to get to tape.
maybe this wont be so bad in the end but im wondering how i could bypass the line inputs,use my outboard pre's and still be able to use all of the functions (VUmeters,tape,input,safe,sel/rep,etc.) of the otari preamps.
im obviously not as advanced as most of you so any help would be appreciated. I do have the manual and all schematics
pstamler
Re: OTARI 7800 need to bypass line ins and use outboard pres
« Reply #1 on: May 06, 2006, 05:03:13 PM »
Quote from: "llamaj1"
I'm not sure what you're trying to achieve. Do the line inputs get padded down and fed through the (dubious) mic preamps? If so, then they're certainly worth bypassing. Do they run through an input line amplifier of dubious quality? If so, then they may be worth bypassing; in either case, the most likely fix (without looking at the schematics) would be to go directly into the input level control. But there are two possible pitfalls. The first is that you have no possibility of using a balanced connection -- in your application that may or may not be an issue. The second is the possibility that the level controls are too heavy a load on your preamps. What is their value?
Peace,
Paul
llamaj1
« Reply #2 on: May 07, 2006, 10:25:44 AM »
Im not quite sure how it works. I found this post from doing a search on this machine http://www.groupdiy.com/index.php?topic=8511&highlight=otari+7800
looks like the mic and line in are connected somehow.
Last post September 11, 2006, 05:38:04 PM
by headcleaner
Last post August 22, 2006, 09:39:44 AM
by nIche
Last post September 19, 2009, 04:33:23 AM
by Tubemooley
Last post December 10, 2012, 10:34:06 PM
by desol
