Ugh, I have a problem.
My console has a point to the bay off the mix buss, I suspect that the point is likely taken from the mix buss summing amps, the return goes to the stereo master fader which drives I think another opamp and a 600:600 transformer. The opamps are discrete little things throughout. The more I think of it, the mix insert point is almost definitely transformerless and its definitely pre master fader.
I plug this into most of my limiters and all hell breaks loose. Into an api 2500, Ive got NOOO bottom end at all, Im talking like hipass filter at 800 HZ. It wont feed the gyraf ssl at all, same thing happens. Ive got a compex with a 10K input transformer thats just total distortion. It sort of sounds better with the daking limiters which have a 10K jensen, but it still sounds like shit. Also, the taper on the master fader is ALL fucked up, its off point moves from the bottom of the fader to the center, very odd.
Oddly enough, a dbx 162 works. I always thought that box had a balanced front end, maybe not... Anyhow, that works great, but I'll be damned if Im gonna put a 162 on my mix buss...
Anyway, the bottom end thing I know form other stuff is likely an impedance mismatch. What do I need to do to make this work? Like an api, my console has all the same opamps that do all the amplifying. Im nearly certain that the buss outputs use two opamps and a transformer to get out of the console. If I put two transformers in a box and patch that between the bay and the limiter, if I used a 1:1 600r transformer, would that do the trick, or am I stuck with having to build an active box with a single gain stage, argh!
I guess what I really need to know is if something wont drive a box with a 10K input transformer, will it drive a 600r transformer?
Only way is to try, but thought Id pose this one to the gurus to see what kind of info I can gather for a fix it day tomorrow. I wasnt expecting this... GRRRR.
thanks for any thoughts-
dave
dave
