J jaotao Active member Joined Jun 22, 2004 Messages 37 Location London UK Aug 10, 2004 #1 No seriously, which VCA's should i get for my GSSL? Which mods for each VCA are needed to get accurate comp ratios? (Ps i should replace 15k's on VCA-in's with 27k right?) any help wud b soo appreciated... have nice days
S Svart Well-known member Joined Jun 4, 2004 Messages 5,134 Location Atlanta GA USA Aug 10, 2004 #2 go for the 2180.. no trim needed. the 15k are fine, try 27k also and see which ones suit your needs better.
J jaotao Active member Joined Jun 22, 2004 Messages 37 Location London UK Aug 10, 2004 #3 remind me what trim is? : )
I Ian MacGregor Well-known member Joined Jun 3, 2004 Messages 280 Location Echo Park, Los Angeles, CA, USA Aug 10, 2004 #4 The trim is a Distortion trim. The 2180s are already pre-trimmed when you get them. It makes setup a lot easier! Ian
M matthias Well-known member Joined Jun 4, 2004 Messages 768 Location germany / frankfurt Aug 11, 2004 #5 when you connected the ssl comp balanced, use 27k, unbalanced 15k resistors... so the input gain is the same 2180 is really fine, you can leave the trimmer and the 68R resistor out for more info look at jakob's ssl meta thread cheers, mat
