tasters
Fender Rhodes piano PCB print
« on: May 16, 2006, 09:04:44 AM »
Hello, i'm searchin' for someone who have, or can print a PCB for the Suitcase verison preamp of the Fender Rhodes piano
like this one, wich i think is from a mark I model:
the better thing is to realize the version for the mark II piano like the one here:
http://www.rhodeslove.it/mark2-preamp-050912.pdf
anyone can help me?
thanks
gyraf
« Reply #1 on: May 16, 2006, 12:17:23 PM »
Hi tasters,
Welcome to GroupDIY!
For a thing like that, the easiest would probably be to ask a pcb manufacturing company..
Jakob E.
tasters
« Reply #2 on: May 16, 2006, 12:42:58 PM »
You know if someone here can print the pcb? or any link for some company? thanks
alk509
« Reply #3 on: May 16, 2006, 12:50:59 PM »
There's this really cool site called Google...
:roll:
Peace,
Al.
Lest laziness get the best of you!
Rochey
« Reply #4 on: May 16, 2006, 12:52:09 PM »
Olimex may be able to help you out - they will take bitmaps of layouts - although it may take some editing first - and they might extra for that.
cheers
R
Expat Audio Home: http://www.expataudio.com
Gus
« Reply #5 on: May 16, 2006, 01:02:48 PM »
copyright problems if you use the orig artwork
mcs
« Reply #6 on: May 16, 2006, 04:22:37 PM »
If you can clean up the image, I can convert it to Gerber format.
Best regards,
Mikkel C. Simonsen
« Reply #7 on: May 16, 2006, 10:01:11 PM »
How do you convert a raster graphic to a gerber?
mcs
« Reply #8 on: May 17, 2006, 06:53:23 AM »
Quote from: "RedHouse"
The correct way to do it, would be to convert the bitmap to vector graphics, and then make a Gerber. I just write the lines in the bitmap as Gerber lines - very crude, but it works...
Best regards,
Mikkel C. Simonsen
« Reply #9 on: May 18, 2006, 12:10:03 AM »
Still isn't clear to me, again how does one convert raster to vector.
(Photoshop to Gerber)
BTW the reason I asked is that I have a bunch of layouts I did in Photoshop, others want them as gerber's, that is why I asked.
Your reply doesn't give me a clue as to how to do it, but thank you.
Mbira
« Reply #10 on: May 18, 2006, 12:23:32 AM »
To start with, you need to get rid of the component overlay, then it is easy from there.
Joel
Joel Laviolette
Rattletree   |  https://www.rattletree.com
The Rattletree School of Marimba | https://www.learnmarimba.com
mcs
« Reply #11 on: May 18, 2006, 07:22:35 AM »
Still isn't clear to me, again how does one convert raster to vector. (Photoshop to Gerber)
Save the bitmap in an easy to read format (like PGM), and then you simply read each line of the image and write all the line segments you find in Gerber format.
If you use a PC OS (DOS, Windoze, *BSD, Linux, OS/2) I can send you a programme to do the work for you...
Best regards,
Mikkel C. Simonsen
« Reply #12 on: May 27, 2006, 04:33:47 PM »
Can you email me so we can talk offline?
brad_anne AT isp DOT com
mcs
« Reply #13 on: May 27, 2006, 04:38:43 PM »
You can just e-mail me - click the little e-mail button :grin:
Best regards,
Mikkel C. Simonsen
« Reply #14 on: June 05, 2006, 10:24:20 PM »
Doh!
Last post July 20, 2004, 10:15:16 PM
by gang of elk
Last post May 19, 2005, 08:58:41 PM
by MLM
Last post May 12, 2019, 06:37:52 AM
by Martin Griffith
Last post August 26, 2019, 11:03:46 PM
by rackmonkey
