mkruger
I'm looking at a Lundahl 1538xl mic transformer. There are four pins in on one side and three out on the other.
IN
Pin 2(+ black wire) of the XLR i would attach to pin 1 of the trafo.
Pin 3(- white wire) of the XLR would go to pin 4 of the trafo.
Pin 1 (ground/shield) of the XLR would go to pin 2 and 3 of the trafo.
OUT
Pin 6 is signal
Pin 7 & 8 are ground.
http://www.lundahl.se/pdfs/datash/1538_8xl.pdf
Do I have this correct for the 1 + 1:5 ratio?
thanks for your help!
-mike
IN
OUT
Pin 6 is signal
-mike
