Bluzzi
GSSL - 2 in one rack. Need advice
« on: May 26, 2006, 10:32:46 AM »
I am putting 2 GSSL in one 3U rack. I want to use 1 transformer and 1 power switch and feed AC to both circuit cards.
This keeps the design the same except for seperate transformer for both GSSL.
or...
Should I feed AC to only 1 card and take the DC  from it to feed the other card after the rectifiers and filter caps?
Jim
gyraf
« Reply #1 on: May 26, 2006, 10:47:06 AM »
Hi Jim,
I think we've had this question several times.
Option2 would probably be the wisest. Double up reservoir capacitance to 2200uF, just in case.
Jakob E.
Bluzzi
« Reply #2 on: May 26, 2006, 10:55:57 AM »
Wow! That was fast!
Actually I kept the same advice you gave me before. I do have the 2200uf as well.
Its good to know that both cases will work out OK.
Thank you for your help as always.
Jim
tommypiper
« Reply #3 on: May 30, 2006, 10:39:44 PM »
You're asking the rectifier and regulators to do double work in that case.  Wouldn't it be easier to just use a large power transformer, and send leads to each board as usual?
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
gyraf
« Reply #4 on: May 31, 2006, 05:34:12 AM »
no. see previous discussions.
Bluzzi
« Reply #5 on: May 31, 2006, 08:24:11 PM »
Why is that Jacob? Would this cause some instability? Is it because of the regulators fighting each other?
I am curious. Thanks
jim
Last post June 06, 2004, 07:33:44 PM
by tubejay
Last post November 02, 2004, 05:13:33 AM
by
Last post February 24, 2005, 01:31:42 PM
by Rob Flinn
Last post May 01, 2006, 01:48:29 PM
by bcarso
