Val_r
The problem is whenever the group mute switch (in the master strip) is pressed. I hear a pop from the audio outputs.
The group mute buss should only supply the 12v for the relays in the muting circuitry of each channel strip.
Why do I hear this thump? Which are the possible causes? (faulty relay, or diode)
Should I remove the strips one by one, or is there a better way to isolate the problem?
Did anyone experience the same problem? Any suggestion?
Val.
Val.
