radiance
Using Lazertran in the Netherlands
« on: August 13, 2004, 12:35:46 PM »
I'm about to finish my SSL clone. The last thing left to do is the frontpanel which I want to do with Lazertran paper.
I bought the paper, made the front panel design..... but I can't find a copy shop in the Netherlands who is willing to let me copy on the Lazertran paper. They are either scared that the paper will jam the copy machine or they think the machine gets to hot (without telling me exactly how hot :mad:  :mad:  :mad: ).
Is there anybody who has experience in using Lazertran paper in Holland or who has experienced the same kind of trouble?
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
nrgrecording
« Reply #1 on: August 13, 2004, 02:21:14 PM »
Either you don't tell them what lazertran is... or you do it like i did... go to your company where you're working everyday... use the copy maschine or colour printer... and don't talk about it (at least if theres smoke in the maschine)  :green:
Look at the brand name of the copy maschine for temperature!
There is a FAQ on the lazertran site:
Which Photo Copiers can be used with Lazertran Papers?
All Canon, Xerox, Minolta, Ricoh and these machines badged under other names. Desk top laser printers that work are QMS and Tektronics provided they fuse at 180 degrees C or less. Alps printers work but you will need our hand made interleaved Lazertran which is the same cost as regular Lazertran.
The key is temperature. Our papers run at a fusing temperatureof 180 degrees C, or lower
Desktop Lazer printers, or Lazerjet printers can run at higher temperatures than this and are so numerous we are unable to test them all. It is safer that you stay with those recommended.
If you have a problem with that... just try the inkjet version:
http://www.lazertran.com/inkjet.html
Please post pictures and infos... if you've got experience with lazertran. I tried lazetran, but didn't have succes with it. Maybe it is nice if you want to make small black letters... but with bigger black areas it don't look fine... but maybe i'd done something wrong..!?
http://www.nrgrecording.de/html/lazetran.html
Regards,
Frank.
Frank Röllen. www.energyrecording.de [FORUM · DIY WEBSITE · STUDIO]°°°° www.frontpanels.de [Engraved Frontpanels]°°°°
nrgrecording
« Reply #2 on: August 13, 2004, 03:14:11 PM »
Quote from: "kubi"
I'm glad, there's an inkjet version, I have no laser printer.
Frank, do you know a source for Lazertran sheets in Germany?
kubi
I'd looked everywhere for a source in germany... nothing...
So i ordered it from the UK. But the sheets aren't really heavy so the
shippings costs are low.   :wink:
for europe ask: [email protected]
radiance
« Reply #3 on: August 13, 2004, 03:22:21 PM »
Thanks for the replies.
I will post pictures of the Lazertran proces, in fact I will post pictures of the whole SSL building proces of corse.... and small black letters is all I need.
@Frank: did you try it another time after you let the aluminum panel in the oven too long (I had a look at your nice webside....)?
nrgrecording
« Reply #4 on: August 13, 2004, 03:37:39 PM »
Quote from: "radiance"
did you try it another time after you let the aluminum panel in the oven too long ?
I tried it with some sheets. But i expected a total shiny surface. The lettering was ok but i tried to test if the surface becomes more unvisibly. I couldn't achieve that.
It is possible to remove the rest of the decal with chemicals (but be careful with that)
Steven Thomas uses fine wire wool abrasive cream after the panel is dried. (haven't tried this, but seems to work good)
Steven Thomas's webpage:
http://monopole.ph.qmw.ac.uk/~thomas/synthdiy/frontpanel.htm
radiance
« Reply #5 on: August 13, 2004, 04:06:45 PM »
Quote from: "nrgrecording"
I plan to do just that. Since I'm working with A4 Lazertran paper I have to cut the frontpanel design in two pieces and print them on one A4 paper. then I have to cut them out and fit them together so if I don't remove the rest of the decal there will be a visible line where the two pieces of the front panel meet.
Twin-x
« Reply #6 on: August 13, 2004, 07:22:09 PM »
Zorg ervoor dat je twee of drie panelen op het zelfde papier print. (heeft bij mij geholpen omdat ik de eerste verkloot heb.)
nathun
« Reply #7 on: August 13, 2004, 07:46:07 PM »
QMS is a Mobile company.  Not that anyone cares (there's so few that I have to give props when i see them)
radiance
« Reply #8 on: August 14, 2004, 06:05:30 AM »
Thanks you all.
@Twin-X: where did you go with your Lazertran? A ordinary copy shop?
I'm from Den Haag and I'm willing to travel to get things done.
Twin-x
« Reply #9 on: August 15, 2004, 06:09:15 PM »
Thanks you all.
I used a laser printer from my work.
Mail me your design and wishes and i will make you one. I have plenty a4 left ;) You can send me clean sheets back if you like.
radiance
« Reply #10 on: August 15, 2004, 07:40:54 PM »
Thanks Twin-X!
Can you PM me your email address  and maybe your address as well so I can sent you the Lazertran papers plus a floppy with the design.
Did you do your Lazertran papers on a lazer printer?
I thought that was not possible but who knows?
I have paper which is for use with colour photocopiers. Do you have the same? Is it possible to lazer print on this paper?
Twin-x
« Reply #11 on: August 16, 2004, 02:23:45 PM »
Thanks Twin-X!
I have exactly the same paper. Trust me i just did trail and error (sh*t my pants doing it but it worked)
I will pm you!
CJ
« Reply #12 on: August 16, 2004, 06:15:41 PM »
i used a heat gun to get rid of most of the shiny surface. i don't think it melts away, but gets mixed in with the paint better.
sanding dulled the clear stuff, so i gave upon that.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
radiance
« Reply #13 on: August 20, 2004, 08:44:32 AM »
Thanks Twin-X! Those prints you made for me look awesome.
« Reply #14 on: October 05, 2004, 07:57:59 AM »
has anyone out there done the graphics for an exact replica frontpanel of a SSL clone?
sorry if I am a little late on this
Last post April 05, 2007, 02:27:09 PM
by
Last post August 03, 2008, 11:35:02 PM
by kazper
Last post October 31, 2011, 01:20:34 PM
by jensenmann
Last post January 20, 2013, 11:44:03 AM
by rob_gould
