I just got myself a power transformer suitable for makeing a a hefty SE amp and I am looking at options for output tubes. I am going to be running around 700-800 volts and I am looking for tubes that will get me at least 20 watts. I was going to use a KT88, I have been wanting to try one of these out running at its upper limmits for awhile now, but I decided to ask around and see what else is out there. This is going to be a utility amp pretty much, mostly for recording bass and guitar, but synths will probably get some use of it also. I mainly want to get an SE amp that will end up with a good range for bass. 6V6 and 6L6 SE amps just do not give a whole lot of breathing room with bass.
Also, is there some reason unknown to me why no one seems to run KT88s SE and with high plate dissapations? Even KT88 datasheets seem to either completely ignore SE amps or just list characteristics of the tube running well below its ability. I suppose I should do some math and figure some loadlines to see if i can answer my own question first. Or maybe its just that they assume normal people will just run Push-Pull instead of pulling 25 watts from a single tube? Would save quite abit of cash on the output iron, but I really perfer the sound of the SE amps.
adam
adam
