soundguy
ADR Compex F760
« Reply #20 on: June 19, 2006, 10:03:50 PM »
I dont know if it is original but its certainly old.  It looks like it was installed the same time as the output transformer but no idea if its factory.  With or without transformers, the adr gain staging is wierd to say the least but I should check on that resistor.
dave
chips are good with dip...
Rob Flinn
ADR Compex F760
« Reply #21 on: June 20, 2006, 05:30:25 AM »
On my 3u f760rs the Gardeners transformer part numbers are marked on th back of the case, where the transformers plug in.  Therefore I believe that the Gardeners tranformers were specified for this version
regards Rob
API
ADR Compex F760
« Reply #22 on: June 20, 2006, 12:40:14 PM »
hi again.
I know that you can still order the original manual from Audio Design.
A friend of mine did that recently and it was not to expensive.
Dennis
[silent:arts]
ADR Compex F760
« Reply #23 on: June 20, 2006, 01:12:56 PM »
add to the transformer info:
all three units we have at work have HAUFE in and out transformers.
a complete documentation would be fine. I have a service manual at work (in german language), but it differs MUCH from the units we have (I found that out the hard way ...)
soundguy
ADR Compex F760
« Reply #24 on: June 20, 2006, 01:17:00 PM »
wow, now thats wierd.  Were those units made in england?  I know ADR licensed that circuit at least to helios, I wonder if at some point a third party was making them in germany?
dave
cannikin
ADR Compex F760
« Reply #25 on: June 20, 2006, 01:35:41 PM »
I think ADR licensed it to a few companies.. Raindirk is another on the list.
Tube limiters..yum!
[silent:arts]
ADR Compex F760
« Reply #26 on: June 20, 2006, 01:52:54 PM »
I think they were unbalanced, and the local distributor added the transformers (prescribed in the germany broadcast market that time)
Re: ADR Compex (Gardiner transformers source?)
« Reply #27 on: October 05, 2016, 10:25:11 PM »
On my 3u f760rs the Gardner transformer part numbers are marked on the back of the case, where the transformers plug in.  Therefore I believe that the Gardner transformers were specified for this version
Hi everyone.
I have a bunch of the ADR rack units, and believe the Gardner transformers were the original specified standard type for my units.  I got a Gardner model number sheet with the units from the seller, with the appropriate in/out transformers indicated on the sheet.
I believe the INPUT type should be either the Gardner MU7530, or alternatively MU7550.
and OUTPUT type should be Gardner MU7524, or alternatively MU7544.
Does anybody have some available, or know where to source these?
Or is it better these days to try to track down the Sowters?
(I think the Sowter 3276 and 3497 transformers were also recommend by ADR & maybe are still available from Sowter today?)
Rob Flinn
Re: ADR Compex F760
« Reply #28 on: October 06, 2016, 05:32:46 AM »
The Gardners are no longer made new as far as I'm aware.  You need to get lucky on ebay or an amateur radio sale etc.
regards Rob
jensenmann
Re: ADR Compex F760
« Reply #29 on: October 06, 2016, 01:19:40 PM »
IIRC Sowter has an archieve online where you can find their direct replacement for those Gardners.
My Vocal Stressor is stuffed with the Sowters you mentioned, btw and it sounds stellar  8)
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
Arny
Re: ADR Compex F760
« Reply #30 on: March 17, 2018, 04:33:52 AM »
My company is Helios Electronics Ltd.
Some years ago we were appointed by AD&R as a workshop for repairing & servicing classic AD&R audio gear.
We keep a full stock of parts including spare "A" & "B" cards,  but most important we also have our own calibration documents which includes setting up the four pré-séts
i.e.
On the "A" card
RV3 (Control Volts)
RV7 (Rectifier Balance
On the "B" card
RV1  (Rectifier Balance)
RV2 (Distortion Null)
Which are not included in the original AD&R service manual or the handwritten documents written by the personal of AD&R.
The only reason I can see why these four mystery Pré-Séts are not mentioned AD&R, is maybe because a Twin Beam scope is required which  most users will not have to hand,  and. chances are if untouched and left at factory settings,  should not give any problems unless of course if your F760/Compex was purchased second hand then you can't be sure these have not been touched by the last owner.
A good quality Twin Beam Scope will  not be cheap, for this reason we are investigating several Android & iOS (Apple) scope applications that maybe suitable for setting up these four Pre-Sets, the results will be attached to our own Calibration Documents.
Also.
The reason why some stereo units sound different and will not balance is because the two FET's on the "B" MUST be a MATCHED PAIR and most likely will have been changed over a certain period of time, which is the reason why they are mounted in sockets, so a perfectly matched pair can  easily be fitted by the owner/user as opposed to  hiring a qualified technician.
We can  supply these FET's in matched/balanced pairs from stock, as well as the documentation for the four mysterious Pré-Séts
Kind Regards
Tony
Tony Arnold (Director)
jensenmann
Re: ADR Compex F760
« Reply #31 on: March 17, 2018, 04:45:41 AM »
Thanks for the information, that really helps.
Jens
Quote from: PRR
tommia
Re: ADR Compex F760
« Reply #32 on: March 23, 2018, 11:51:12 AM »
Hi Arny,
what is the price for the matched FET's
Last post May 30, 2005, 04:39:37 PM
by soundguy
Last post December 10, 2006, 08:20:09 PM
by hodad
Last post January 22, 2007, 12:10:28 PM
by SSLtech
Last post February 08, 2013, 08:50:56 PM
by barclaycon
