Relay PCBs
guavatone
USA
does anyone have any input relay PCB designs to DIY-etch. I am trying to use relays for 48v, and padding. I am in the process of drawing them myself but things are so busy now.
A thousand thank you's to anyone that can help.
PS I am also planning on doing a resistor based Z-select and output XFMR termination, but that may be out of the scope of what people may have.
Peter P has one lying around that did exactly that 48V +pad+polarity - usign relays
I will try and hunt it down
http://www.groupdiy.com/index.php?topic=7668&highlight=phantom+pad+relay
But the pictures have gone walkies - ask Peter nicely
Thank you so much Peter. You are a STAR! I will make good use of these and post mods if I go that way, so others may benefit too.
