giantbenny
G9 with a difference THANKS to JLM This Baby Kicks Butt
« on: June 28, 2006, 10:30:09 AM »
Hey Everybody Get a Load of this
I decided to build up a single channel G9 and do some transformer swaps, take some measurements etc.
I called Joe Malone JLM {Daddy Animal (Baby's Dad)} and ordered a few transformers to AB with the Lundahl I already had.
The Building Process went very smoothly, no probs or set backs.  I Started off with the Lundahl, I was Pretty Impressed, tonally it was warm and clean, although it was pretty quiet.  Then I tried the Oep, it was a bit better, still smooth but with a bit more punch maybe an extra 1 or 2 db, nice colour and minimal distortion.
Then I tried the JLM DC,  AND I DAMN NEAR FELL OFF MY CHAIR, IT SOUNDED SUPERB, the difference was like that of a v7680 and a b*hringer tube comp*ser.
under load, we pulled an extra 12 db from it, and again thanks to more advice by Joe, I changed the 4u7 250 to a 20u 400 and opened up the bottom end.
This is the best combination i have seen yet, sorry i'm not being extremely techo'ish.  but i when i do, i only sound like an intern in a room full of neurosurgeons.
But i do know sound and this baby sings.  I miked up a guitar afterwards and to be expected, it sounded great too.
I'll get some pics posted tomorrow, it is messy as hell but it fired up first go.
cheers,
Purusha
« Reply #1 on: June 28, 2006, 03:03:40 PM »
I am still contemplating different pres to DIY. Would you be so kind and share how much $$$ for such a G9 project. You can give me the price without the case though.
And some pictures please!!!  :grin:p
Regards as always, Purusha
Kingston
« Reply #2 on: June 28, 2006, 03:16:07 PM »
Quote from: "Purusha"
You might want to consider another just as valid project, the newyorkdave MILA-1, or the two-bottle. Price would range somewhere around 70-200e per channel, depending on quality of caps, tube availability and transformers used (and wether you want to stay unbalanced) etc.
Nele
« Reply #3 on: June 28, 2006, 06:39:52 PM »
Sounds interesting! I've been thinking about changing the output caps to higher quality/value.. Looking forward to seeing the pix.
Corneel
evan38109
« Reply #4 on: June 28, 2006, 07:04:57 PM »
I'm curious: how would you describe the difference in sound with the JLM?
 - E
giantbenny
« Reply #5 on: June 28, 2006, 08:46:05 PM »
Quote from: "evan38109"
 - E
The difference is not small put it that way, the JLM seems to open the back door and let the breeze flow through, tonally it is more open and transparent, drives very well, distortion levels are decreased and it sounds very warm without the artifacts. On vocals it is very breathy and full, and on guitar it has just the right amount of warmth to make it sound as if you are right next to it.
hope that helps
mikeyB
« Reply #6 on: July 04, 2006, 06:54:40 AM »
Are you using the same components as per schematic other than a big fat 20u400V and JLM transformer. Have you changed anything else? I assume that's a OEP262A3E on the input?
making better music!
ChrioN
« Reply #7 on: July 04, 2006, 07:19:15 AM »
Nice layout btw. Making room for some vu meters?  :thumb:
"All PCB traces are curved to emulate the electrical response of point-to-point wiring" -Drip
giantbenny
« Reply #8 on: July 06, 2006, 08:10:32 AM »
Quote from: "ChrioN"
yeah, i do love vu's i'm just going to build up a simple metre driver circuit, and parrallel it switchable between input and output.
thanks
giantbenny
« Reply #9 on: July 06, 2006, 08:13:03 AM »
Quote from: "mikeyB"
yeah thats right, the only other difference is that i am using 12ax7 (lps) tubes, they have measured up better than the ecc82s
ben
JLM Baby Animal
Started by jmiller « 1 2 ... 51 52 » Preamplifiers
Last post September 07, 2018, 10:04:17 PM
by MatC
Last post August 01, 2006, 10:38:38 PM
by mattmoogus
Last post December 11, 2006, 05:01:06 AM
by zul_nalury
Last post February 23, 2021, 05:19:32 PM
by Tubetec
