khstudio
This pre sounds GREAT but what is going on in the low end? :shock:
The right channel is the raw, sound card looped back in & the white/left channel is the PM1000.
The output cap is a Panasonic FC 100uf, stock value was 33uf & was Bi-Polar... could the fact that the new cap NOT being Bi-Polar cause this?
The EQ was set flat & it had the same curve with different gain setting. I also have 2 units & they both react the same. :roll:
Kevin
Kevin
