rlackey
Member
Hi guys,
I would like some input on the curcuit below.
The original paper and diagram are here:
http://www.cgs.synth.net/tube/vca.html
I have nowhere to host my own pictures yet, so I can't provide a link to my own schematic. It's basically identical to the one on the link above but I don't need the supressor grid so I tied it to the cathode.
According to the original designer, the gain should be linear up to a CV of 3v, making it compatible with solid state CV sources.
I am looking for something I can use as a digitally controlled volume control where CV is controlled through something like a 1024 step digital potentiometer, in turn controlled in 10bit resolution by a suitable microcontroller.
I want to keep the audio passing only through tube curcuitry.
Will this work? Anyone have any other better ideas. I think this is still going to need an additional gain stage as well, probably any pre amp would work.
This is about the simplest thing I could come up with for what I want to do. I have an Electro Harmonix EF86 to play with. They are a bit expensive though, I am not sure if there is another pentode that would also work and cost a bit less.
What do you think? Any suggestions?
Rich :grin:
Rich :grin:
