Back With another quickie..Pot Grnd..
jeth
Uk/Mexico
Hey all, been a while..
Just a quickie..
If I have 3 volume pots for 3 different channels...is it ok to put a ground connection across the bottom of all 3 then just run that back to circuit ground,(rather than running 3 individual wires back) or is that likely to cause a problem?
Thanks for the replies folks, still pretty much a newb, so nice to be able to confirm these things.
Svart.. When you say seperate connections as pàrt of the ground scheme..Do you mean actually running the individual pot grounds back to the main star ground point directly, or just to "local" circuit ground, which in turn would be connected to the star point?
