Geert Heyrman
Hello,
I'm currently working on some schematics to balance the inserts on my studer mixing desks. I have found the perfect schematic for balancing (send) and debalancing (return) in a nice little pakage. It is used in a certain fadermodule of the studer. As I have to normal the inserts on the patchbay I would like to use a relay to activate or deactivate the insert so I can keep the signal path as short as possible and don't have to normal the patchbay itself, when I don't use the insert. The insert itself is unbalanced. So I would like to use a relay before the balancing and debalancing amplifier. Does anyone have any suggestions with regard to the best cirquit for this option. I have no experience with relays so every help is welcome.
By the way I have the schematics and bill of materials finished in free PCB for the balancing and debalancing . If someone want's to host it that would be great so everyone can use this for balancing their inserts. I think it's a schematic everyone could use. The schematic uses two NE5532N dual opamps. It's really small (like 5.5 cm on 3.5 cm) and uses +- 15Volts to power it.
Regards,
Geert
Regards,
Geert
