Balanced unbalanced line-in question
kiira
Baltimore - Blobsville USA
Quick dumb question about my NYD-2b... I have a stereo 1/4" jack on the front panel for line-in and that goes to the 10k:10k xformer acourse.. Is there a way to do it different so I could use both balanced and unbalanced line-in? The way it is now only half the transformer would get input.. the sleeve on the mono jack goes to ground .
Kiira
As long as you have it wired like this:
primary + to T
primary - to R
shield/ground to S
inserting a TS jack will automatically pull the primary - to ground, giving you an unbalanced input. Simple eh? :cool:
The only problem would be if you had a TRS with nothing wired to the R. Then youd get the familiar one legged transformer bleed sound (very quiet high freq only).
M@
[quote author="mattmoogus"]As long as you have it wired like this:
primary + to T
primary - to R
shield/ground to S
[/quote]
Ah ha! So the ring of a trs jack will touch the sleeve (ground) of a regular TS jack. I thought it floated. Yes I wired it that way. lol it would have worked if I'd tried it.
thanks,
Kiira
