pucho812
Andrew or anybody.
This seems so simple but the problem is escaping me. got 2 PSU both with the same problem both for the floressent metering. Both with no load on them appear working at normal parameters. All Voltage LED's, +/-15V, 5V and 23Vct, turn on without issuse. the moment the meters are connected in I loose 23Vct since I havn't worked with the VF metering and the manual is semi lacking in trobleshooting tips I am trying to figure where to go next. there is a voltage trim :? for the 23V or it could be as simple as misconnected as the original owner's labeling was complete shyte and I had to reconnect via what the manual said as opposed to what was labeled. single connector on the back of the PSU barrier strip on the back of the board. Maybe this is wrong too? urgh the board fired up without major issue other then a sctracy pot. what the hell are these meters such an issue.
Mislabeling on part of the seller. All working now. :twisted: :grin:
