innercityman
Re: The official G9 help thread
« Reply #2200 on: March 01, 2020, 06:05:43 AM »
Ok, Thanks TiIIM !
innercityman
« Reply #2201 on: March 20, 2020, 11:05:55 AM »
Hi there,
I finished soldering every components. Is there a wiring guide somewhere ? I'm just wondering how the 2 big PSU caps are wired ? I'm using the don-audio's special designed single Power transformer.
gyraf
« Reply #2202 on: March 20, 2020, 10:05:47 PM »
Then maybe ask Don-Audio how to wire it?
Jakob E.
TillM
« Reply #2203 on: March 21, 2020, 12:38:34 AM »
It's easy to wire it !
It's all AC on the secondary.
He also has a wiring guide on this website.
But there a two on this website.
Do you have the cheaper one or the one with the white housing ?
innercityman
« Reply #2204 on: March 21, 2020, 06:23:20 PM »
I bought the expensive one with white housing. Specially designed for the G9. But I can't find informations on how the two PSU caps are connected.
TillM
« Reply #2205 on: March 22, 2020, 01:46:36 AM »
See at the schematic !
Or look at some photos.
The minus poles from the capacitors went to the middle on the pcb. The plus poles on left to it, from the other capacitor right to it.
Connect both minus poles to the middle.
innercityman
« Reply #2206 on: March 22, 2020, 01:53:20 PM »
Not sure to understand but anyway thanks for your help. I'll check the schematic.
TillM
« Reply #2207 on: March 22, 2020, 02:06:27 PM »
I hope that this will help you.
innercityman
« Reply #2208 on: March 25, 2020, 10:51:31 AM »
Thanks Tiim, I've already checked on Jakob's layout and found out.
I have another probably dumb question anyway... How do you set 2 positions on a Lorlin 3 positions switch. I mean, for the phase switch, there should be 2 positions right ? Normal or inverted. So is it possible to do that ?
innercityman
« Reply #2209 on: March 25, 2020, 10:57:53 AM »
I found out, sorry. Needed to pull up the bolt of the switch to access the adjustment ring.
gyraf
« Reply #2210 on: March 25, 2020, 11:01:29 AM »
:-) edit
Last post November 04, 2014, 01:23:59 AM
by gyraf
Last post April 29, 2018, 04:42:48 AM
by insideout
Last post September 14, 2014, 05:41:22 PM
by applebeach
Last post October 21, 2017, 11:05:54 AM
by ward
