I am building a simple tube tester for checking tubes to use in microphones and piezo amps. Just took a break most is done being built on a piece of plywood and parts I have
I am building close to some "standard" operating points in tube microphones
What is is so far a zener regulated 150V or 75V B+ switchable fixed 100K plate R
two DC heater voltages switchable
Fixed bias voltage I picked about -1.5V DC to start.
I wire up sockets for different tubes with 100K grid to ground(for now need to order some high value Rs). Plan add a grid current section,. switch in and out the 100K across maybe a 1gig
The idea is cheap but hopfully good
set the supply to 150V B+ to start and A heater voltage
let tube warm up for some time measure voltages across the plate R and Plate to cathode
switch the voltage to 75VDC B+ same heater voltage and grid voltage measure again
Knowing the plate is 100K cal the plate current (V drop across the plate R/ 100K)
Rp should be tube voltage plate to cathode / plate current at both 150VDC and 75VDC
rp (dynamic plate R) should be delta tube voltage/delta plate current (this is at a fixed -1.5V a close value for a lot of tube microphones) I might make the bias voltage switchable in the future (delta changes from 150VDC and 75VDC at a fixed bias voltage)
I then want to do this again at underheating voltages.
Why switchable and not pots? maybe a microcontroller measuring setup.
What do you people think? Anything I got wrong with this so far?
Yes more B+ and bias voltages might be good add, but maybe two B+ might be enought. G3 to ground or plate switch etc.
