[quote author="gyraf"]:razz:
Yes, if you need a +4/-10 switchable output, you can simply use a pad at the output.
14dB is 5x (or 0.2x) gain.
[/quote]
Don't forget that it's +4dBu, and -10dBV. The reference points are different, so the actual difference in level is closer to 12dB (or 0.25x).
For unbalanced, use a simple resistor divider with e.g.. 4K7/1K, for balanced use a H-pad with e.g. two 4K7's and a 2K2 (roughly)
You could even have both outputs at the same time on two connectors.
[/quote]
Often, but by no means always, a +4dBu output will be balanced, and a -10dBV output will be unbalanced. In the case of some active outputs, you can achieve 6dB of attenuation by just ignoring the -ve leg. In that case, only a further 6dB (0.5x) attenuation is required to get down to a -10dBV unbalanced output.
Steve.
