Pultec MEQ-5 EQ full schematic
tardishead
Sussex, UK
I cant find the schematic for the Pultec MEQ-5 EQ amplifier section with the Triad HS50. Has someone got it somewhere?
an I tripping or is the output section a Pultec MB1 mic pre??????
Well, the filter section has been posted many times. But the amplifier portion is a little harder to find. Let me dig around. I can't promise anything.
ok, 259.7 kb, so watch it!
http://vacuumbrain.com/The_Lab/TA/Pultec/MEQ5/meq_5.jpg
before I learned to use a scanner, no doubt.
cross sectorized coils on the 56, only possible on a 1:1 or other low integer, balanced strays for bandwidth.
where the h have you been?
surfing off the mainland or elsewhere?
Thanks th Greg Boboski for the filter section, never seen a real MEQ 5 filter doc, which is kinda scary, but mine works, so wtf, over?
hey guys
I want to build a EQP1A but I want to use the output section of the MEQ5 because I have the transformers for it.
Can I use one output section in the other - does it give about the same makeup gain?
QUEEF BAG said:
not sure if this is what CJ posted, but it's the same size...
[/quote
Thank's for this !
I don't think if it's the same. But CJ can tell us that.
I believe that's the one -thank you very much!
After searching for ages for schematic, giving up and asking for it, I stumble across a second one here: http://www.groupdiy.com/index.php?topic=23004.msg274012#msg274012
It looks to be the same as the one QUEEFBAG posted.
