versuviusx
can i burn up these transistors?
« on: September 27, 2006, 12:27:30 AM »
hi i'm using :
PN4250A
TIS98
2n2102
2n4036
2SA798
i just starting soldering with them and then i wondered if it were possible for me to destroy them by not using alligators to insulate them. i've heard that some transistors can get burned up when installing them...and i just want to be careful.
please let me know
clintrubber
« Reply #1 on: September 27, 2006, 07:29:47 AM »
Some types are more sensitive than others, but while there'll be solder recommendations in the datasheets that may differ from type to type, listing these type-no's might be overspecific  :wink:
As for most things in life, don't overdo. Solder the wire-links & passive components on the PCB first & then do the semiconductors. A few seconds should be OK, but if you need half a minute to get a good solderjoint then reconsider some more solder-practice with already broken components.
Have a look around for solder-guides if you haven't already. Lots of good info available.
Regards,
  Peter
kato
« Reply #2 on: September 27, 2006, 07:34:57 AM »
I asked this same question a while back (not with specific part numbers) and PRR responded to the effect that transisitors are not as fragile as we're often led to believe.
Still, I would keep the soldering time short!
Last post January 23, 2005, 12:40:52 AM
by holger honda
Last post March 13, 2009, 01:26:24 PM
by rodabod
Last post March 17, 2015, 07:18:07 PM
by pcsnpny
Last post February 09, 2011, 12:06:03 AM
by EmRR
