meaning, I often see the notation CW or CCW on schematics. One thing puzzles me and that is the position we need to see the potentiometer itself. Is it to be seen from the position like where you would put the pot as on your frontpanel (shaft pointing at you) or from the bottomside? I had a few times the problem that after soldering something together the min position became max and vice versa... this must be simple to prevent innit? I'm sure this is very basic knowledge, however a flaw in my limited diy wisdom
