Meta - EQ (general and everything non passive)
nhaudio
Barcelona, Spain
I tried to create a meta on eq in general and non-passive eq threads. let me know or add if you find other posts about it.
cheers,
Nicolas
Some Links for theory info on EQ - 3 or 4 Band Fixed EQ.! ( For Tone)
http://www.groupdiy.com/index.php?topic=18079
Links of schematics for parametric EQs - Parametric EQ
http://www.groupdiy.com/index.php?topic=14764
Which Parametric EQ is best between Brit eq, calrec or alesis x2 - Parametric eq
http://www.groupdiy.com/index.php?topic=17173
Title says all - transformer recommendations for a parametric eq ?
http://www.groupdiy.com/index.php?topic=16640
Title says all - newbie help for balanced I/O in an eq :shock:
http://www.groupdiy.com/index.php?topic=16336
Schem, examples and info on one band parametric EQ and pics of work done(Schem for the S0undcraft gh0st EQ) - simple parametric per channel
http://www.groupdiy.com/index.php?topic=16457
title says most of it, links for portereq - Parmetric eq with instrument input
http://www.groupdiy.com/index.php?topic=16412
Links schem of various A*P*I eq and diference between 560 and 550 eq - A*P*I 560
http://www.groupdiy.com/index.php?topic=1465
title says all - parametic eq mounted on a push-pull pot?
http://www.groupdiy.com/index.php?topic=15943
On concept of Dynamic EQ ( vca compressor + parametric EQ) - Dynamic EQ?
http://www.groupdiy.com/index.php?topic=14090
On where EQ should be in mastering chain - Mastering Signal Chain....
http://www.groupdiy.com/index.php?topic=13383
Can you make a "compact" parametric EQ and various factors around parametric EQs - Parametric EQ?
http://www.groupdiy.com/index.php?topic=12088
on GM- eL type 8200 EQ and Fabio's "sontec" - anyone built a GM- eL type 8200 EQ
http://www.groupdiy.com/index.php?topic=11922
link to Amek M2500 EQ and discussion on it - Parametric Eq
http://www.groupdiy.com/index.php?topic=7979
Schem for Graphical EQ - Newbie wants to make a graphic EQ
http://www.groupdiy.com/index.php?topic=6680
Title says all - Alesis X2 schematics if you need them...
http://www.groupdiy.com/index.php?topic=5691
Netq pcb tracing and schem, discussion on sontec - parametric EQ
http://www.groupdiy.com/index.php?topic=4409
Building an analog "finalizer" - In-ear finalizer/mastering device: anybody interested???
http://www.groupdiy.com/index.php?topic=2892
Title says it - Schematic for TC2240 EQ?
http://www.groupdiy.com/index.php?topic=669
on Fabio's Sontec - The Sontec thread! <ATT. BUILDERS - C22 & C23>
http://www.groupdiy.com/index.php?topic=36
which relay for Calrec (mbb or bbm?)- Some Gyraf DIY Calrec EQ questions...
http://www.groupdiy.com/index.php?topic=18542
Gyraf Calrec EQ - PCB Rev 5- title says all
http://www.groupdiy.com/index.php?topic=538&postdays=0&postorder=asc&start=0
3D "AIR" EQ - FULL VERSION PCB'S COMPLETED!!!- Everything you need to know to build your own "air" EQ - also called "Night EQ" in the Forum
http://www.groupdiy.com/index.php?topic=19789
