clintrubber
Having typed a reply to PRRs informative words on
"Looking for SE540 / NE540 info" last week I logged in to
post but things had changed... (and the rest we know).
Good everything's up & running again !
Wanted to add this:
Thanks PRR for your time & trouble to provide this info.
Wishing you many tasteful meals from your new kitchen :wink:
>> That +/-12V supply looks underwhelming
... but not really:
You're right, the healthy signal-levels can be there and fit the +/-12V supply. Just too focused on maxing out supply-voltages...
As I understood from the words above, for todays standards this linedriver-circuit is nothing special and its performance easily surpassed by more common components, although it has its uses.
There's of course still the fun of keeping an old PCB into service.
OK, I'll wire it up a bit further and use it with or without the output TXs - of which I now guess they're better 'spent' for another circuit. For the time being though could use them wityh the original driving stage.
About the quiescent current of the output devices being
1.65*Vbe (instead of 2*Vbe as in the Walt Jung-circuit):
what I saw so far is that those output bipolars as used in
the Ampex-circuit are of about the same dissipation rating
as those in the Jung-circuit, so biasing the Ampex-version
a bit hotter seems possible without further mods, correct ?
Or is there something I'm overlooking for the '540 ?
Can check if there's a worthwhile THD-improvement.
Regards,
Peter
Wanted to add this:
... but not really:
The Ampex design uses an imprecise idle bias current setting. Thermal tracking is not an issue because the bias is set to 1.65 Vbe, and Q5 Q6 probably idle at very low current. Probably just enough to make crossover distortion very small, relying on massive feedback to eliminate the last bit of crud. It is a dirty trick that often does not sound bad, and is still popular because a high-bias Class AB stage is more troublesome in mass production.
Regards,
Peter
