Hi firends, I have problem with the noise of my compressor.
Here is fft taken from spectralab:
http://www.picvalley.net/u/41/40571_489.GIF
I read -32dBv using my fluke and -36dB using cool edit.
Here are picture inside:
http://www.picvalley.net/u/29/28005_573.JPG
I connect earth to pin 1 on every XLR connector, but this decrease noise only with 3 db ;(
I solder 100nf capacitors direct to any opamp and that chips.
What I found. In any configuration of ssl this nois doesnt change. I connect input to gnd. Try to use externel sidechain. change threshold and makeup, and the noise is the same
Any ideas?
Thanks.
Any ideas?
Thanks.
