OK, got to wind a few more tonight, the ferrite core is looking good.
For the 800 ish mH coil, 250 turns does the trick.
This is a lot better than hand winding 450, eh?
I found out an interesting winding tweak on these torroids, these two coils have exactly the same turns.
But they are about ten percent apart as far as inductance and resonance.
The only diff is the pitch at which the wire was wound.
I found the resonant frequency of the inductor with a 0.1 cap in series with the following circuit.
Put one trace across the cap, another traee across the coil, and sweep it til the levels are equal.
Then, recored the frequency, place one scope lead across the resistor, and sweep it for the max voltage across the resistor.
The frequency at which this happens shoule be the same or very close to the frequency found with the dual trace mode.
It's just a double check.
Here, the frequency is below resonance, so the reactances( ac resistance of the cap and inductor) are not equal.
There is more voltage across the cap because its reactance increase as frequency drops.
Now we have gone past the resonanc frequency, and the voltage across the inductor is greater than the voltage on the cap, because as frequency increases, it's reactance increases:
Now we have found the resonant point.
Both voltages are equal, the reactances of the induxctor and the cap are the same, the defination of resonant frequency.
OK, we will wind the rest and check the diff between iron and powdered cores. HAppy Halloween!
cj
