OPA 2604 buffer
sonicmook56
Los Angeles | Echo Park
Hi-
I want to use an opa 2604 op amp as a buffer setup like the model on page 12 (figure 9) on the datasheet. I’m not an EE, so please excuse any ignorance.
http://focus.ti.com/lit/ds/sbos006/sbos006.pdf
The worst case load senearo, this buffer will need to drive around 500ohms, (best 640ohms) at unity gain.
A coupe of questions for you guys –
1. Whats the function of R1 in this model?
2. My math says if R2 is 0ohms, then It will be unity. Is there a better way to use R1/R2 to get unity gain?
3. Does Vout/ Itotal give the absolute load this buffer can drive? I get about 25 ohms.
Gain 3.472=3.472(1+0/20000)
Output load 3.472/0.1361 = 25.51ohms?? dosent seem like a real figure to me.
:guinness: :guinness:
edited for clarity
[quote author="sonicmook56"]The worst case load senearo, this buffer will need to drive around 500ohms, (best 640ohms) at unity gain.
1. Whats the function of R1 in this model?[/quote]
R1 and R2 form a classic feedback network for a non-inverting opamp circuit. Gain = 1 + R2/R1.
Yes: omit R1.
Where does that figure of 3.472 come from?
Peace,
Paul
[quote author="pstamler"]
[/quote]
Thanks Paul.
3.472 is Vpp for +4dBu. I figured that was a good place to start when trying to figure out the total load. I could probably just use "1" for the math?
How would one choose the correct value of R1.... 10k? 20k? 100k? why?
No because you'd get horribly high distortion. I'd say 600 ohm is the lowest load you should try. If you need more, a discrete output stage looks like a way better solution.
Samuel
Put in a BUF634 in serie with the OPA output before the feedback resistor then you will be able to drive heavy loads.
max 250mA
2000v/uS
[quote author="sonicmook56"]I only need to drive 500ohms in the worst case scenario.
The 2604 shoud be able to do this set up as in figure 9 of the datasheet... :?: no?[/quote]
For unity gain, just build figure 9 with R1 omitted and R2 as a short circuit. Make sure you put adequate decoupling on the amplifier(s): 100nF ceramic across pins 4 and 8 (if OPA2604) or between pins 4 and 7 on both devices if using 2xOPA604.
PS your avatar isn't working
I'm finding the 604 series to lack greatly in a lot of aspects.
Look at some of the opamps designed to drive cables, a lot of them can drive down to 75R easily.
I use tris to drive lines:
Yes. A single amplifier should be able to drive 600 ohms, so the double-amplifier shown should do 300 ohms okay.
For stability, do the 100nF cap between V+ and V-, but also put caps from V+ to ground and V- to ground, close to the amp's pins. Put 100 ohms in series with the output to avoid instability when driving long lines -- it'll lose you 1.6dB of level, but that's not usually a big deal.
Peace,
Paul
