SSLtech
Mic output transformers...
« on: November 16, 2006, 05:16:55 PM »
I need to build a few (note: a few!) microphones. All of them need to be pretty closely matched -if that matters to the question which I'm about to ask...
If I were to build a KM84 type circuit, what would be a good output transformer to use for the (originally listed as 7:1) step-down output transformer?
Or could I wind my own, and if so, would a respected member of the community such as our resident hacksaw fiend assist with how to go about getting the metals, bobbins, etc.?
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
AnalogPackrat
« Reply #1 on: November 16, 2006, 05:32:16 PM »
Read the METAs!   :grin:
Check CineMag for a reasonably priced US-made part.  Just call or email and they'll answer your questions and provide a quote.  Email sometimes takes them a couple of days (possibly longer with the holiday next week).
A P
If it is to be, it is up to me.
SSLtech
« Reply #2 on: November 16, 2006, 08:11:28 PM »
Okay,
I found the group buy here...
-I keep getting distracted here at home, couldn't readily figure out the number for that particular transformer combination that you mentioned...
How long approximately would this group buy take, also what are the sizes... -I have to be able to fit 4 of them inside a single mic body...
I'm thinking the subminiature xfmr case, NOT PCB pin mounted (for handling/robustness reasons) probably stud/screw mounted with flying leads...
Keith
Quote from: PRR
Gus
« Reply #3 on: November 16, 2006, 10:12:48 PM »
I like to use the LL1636 wired 10:1 with km84 type circuits.
  And a fairchild(national semiconductor) Process 50 fet.
skipwave
« Reply #4 on: November 17, 2006, 01:14:36 AM »
Howsabout the beyer 3.51.0.07.004? That would be perfect if you want 7:1 and screw mount with flying leads, 200 ohm output.
I was hoping to grab a couple of these, but we'll see if I have any money before the group buy ends.
Quote from: "SSLtech"
Quote from: PRR
Now, maybe you don't, or shouldn't, grab the ribbon for far-harpsichord, nor the hot condenser for snare-kissing... yet often we do.
gyraf
« Reply #5 on: November 17, 2006, 03:49:33 AM »
Building your own Soundfield now, eh?  :razz:
I've had very good results with the Beyer 1:10 mic input transformers reversed.
For a very-clean trafo - but considerably larger - Lundahl LL1530, 1:7
Jakob E.
SSLtech
« Reply #6 on: November 17, 2006, 09:39:14 AM »
Quote from: "gyraf"
Em...
Errr...
Well, not exactly[/u]...
-You'll have to wait and see. Yes, it's planned to be a clever mic rather like the soundfield, yes there are four capsules, but it's not a soundfield as such, and there'll be no tetrahedral array. Some of the math will be similar, but then the Sondfield once you get out of tetrahedral 'A-format' is just fundamental, rather simple stuff... though a lot of people are scared of it... -I know I was rather apprehensive until I discovered just how stunningly basic it actually was once you got past the tetrahedral stage...
So I won't announce anything until it takes shape... then we'll all see how it turns out.
Keith
Quote from: PRR
Last post June 17, 2019, 04:14:30 AM
by gyraf
Last post July 02, 2006, 12:34:11 PM
by SUPERMAGOO
Last post February 17, 2006, 01:58:54 PM
by CJ
Last post May 20, 2006, 08:07:59 PM
by andy_simpson
