sbeach
Active member
I'm putting together a project that incorporates standard opamps at +/- 16v & a few discrete opamps using +/- 24v. I want to use just one bipolar power supply for both types of opamp. I could use a second LM317/LM337 pair of regulators set for +/- 16v in series on the already regulated 24v supply output; or I thought I might incorporate a zener regulation scheme for the lower voltages. I found a zener voltage regulator calculator on the Opamp Labs web site & came up with the resistor value shown in this schematic.
http://www.twin-x.com/groupdiy/displayimage.php?pid=325&fullsize=1
Also, the web site only showed an example illustration for regulating a positive voltage. I adapted that for the -16v regulation schematic - possibly incorrectly. I also added the RC filter after the zener to clean up the output a bit. It was NOT in the original illustration.
Did I adapt that orignal schematic correctly to accomodate the -16v regulation? Since the voltage gain of the standard +/- 16v opamp is small to moderate & the load a fairly high impedance (50k), should I consider using a 1N4745 16 v 15.5 mA DO-41 zener diode instead of the 50mA one as shown in the schematic? Will the zener regulator approach be dirtier or noisier than using a second pair of dedicated regulators like the LM317/LM337 series? I know it's cheaper & has a slightly smaller footprint but I don't want to be challenging the PSRR of the standard opamp.
Ideas, comments or suggestions?
Skip Beach
Skip Beach
