Just knocked up a G7 circuit point to point, was plannining to borrow AKG Solid tubes capsule to see if I have the G7 working ok...
Dale116do7 kindly wrote...
"take the capsule bias resistor to ground instead of +62 volts."
Im not as technical as most ..is the bias res the 33 meg ??
also the solid capsule only has 2 connections..??
can anyone point me right im worried I may harm the solid capsule you see.
If I get that end connected right, I need output transformer, I have a OEP A262A2E laying around, I read via some searches some1 used a different model OEP with success perhaps I could just use it for a test.
The plan is to get a Peluso capsule and good tranformer if all looks well
Thanks guys...........................Gary O.
